connector function
Im Mark from the Netherlands Amsterdam
I have 3 questions about functions of connectors and hoses
Can somebody please help me and advise what it is
Many thanks
this is by the battery tray
this hose is coming from the engine
this connector is at the same point as the antenna
I looked at your other posts and saw you have a 2002 EG.
I think part #15, Vapor Valve may be the first picture. The clean spot on the top looks like it had a hose on it. Can't tell from the pictures but can the hose in the other picture hook to the valve?
http://partsfinder.onlinemicrofiche....-%20CARBURETED
Do you have a tour pak? Looks like the connector could be #65 in the drawing
http://partsfinder.onlinemicrofiche....RING%20HARNESS
http://partsfinder.onlinemicrofiche....=16&c=0&d=2002 FLHTC TOURING ELECTRA GLIDE® CLASSIC (CARB) (DJ) TRANSMISSION BEARINGS W/ SIDE COVERS
The connector in pic 4 & 5 should be #65
http://partsfinder.onlinemicrofiche....=53&c=0&d=2002 FLHTC TOURING ELECTRA GLIDE® CLASSIC (CARB) (DJ) ELECTRICAL - MAIN WIRING HARNESS
which should plug into #31 on the Tour-pak (for the lights)
http://partsfinder.onlinemicrofiche....=34&c=0&d=2002 FLHTC TOURING ELECTRA GLIDE® CLASSIC (CARB) (DJ) LUGGAGE BOX
