BCM malfunction
Old Sep 14, 2020 | 09:21 AM
Erzsebet's Avatar
Erzsebet
Default BCM malfunction
Hi, I have a Harley Davidson 2014 fatboy lo. I cannot start the engine as the following error message appear.
B2121: starter output open/BCM malfunction. Does anyone have any idea how I could solve this problem? I have checked battery but it is working well I can use it for another bike. I have also checked relays and wires it seems everything is working well, just I cannot start the engine.
The bike has got American BCM and European RCM, could this be the problem?
Thanks
Old Sep 14, 2020 | 05:03 PM
Zanthamos's Avatar
Zanthamos
According to the parts fiche only one model of each, no domestic and international versions. Looks like a BCM issue though. There are 2 models of BCM, base level and security so double-check the part number.
Old Sep 14, 2020 | 08:49 PM
Crotonrz's Avatar
Crotonrz
Have you checked that the trigger wire to your starter is plugged in? Single Red/Black wire running into starter? If so, the flow chart is basically check if you have voltage at the starter, on the wire I just referenced when you are pressing the starter button, if yes, then it would be a starter solenoid issue. If no, they have you check voltage at the BCM that feeds that wire, however the only way I recommend doing that, is with a breakout box. From there, it's either a broken/cut/pinched Red/Black wire from the BCM to starter if voltage is present, or it's a bad BCM if not. Because it's throwing this code, it is receiving the signal from the Start button, so its not a switch issue.
Old Sep 14, 2020 | 11:18 PM
Erzsebet's Avatar
Erzsebet
I have tried to start the bike with a switch of another bike. So another start button. It was not working.
Erzsebet's Avatar
Erzsebet
My mechanic told me there is no security in the bike.
Old Sep 15, 2020 | 07:25 AM
Crotonrz's Avatar
Crotonrz
I didn't think it was a switch issue, but did you check that everything is plugged in, and voltage at the starter trigger wire when the start button is pressed? What I have described is the flow chart to diagnose the code you have, while you may not have a breakout box for the 2nd part of the testing, you should be able to do the first part with a test light, although a multimeter is always ideal to see actual voltage.
Old Sep 16, 2020 | 09:32 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
What is the story of this bike?
Did this issue just happen?
Has this bike run properly with the BCM that is currently installed?
Old Sep 17, 2020 | 10:10 AM
Erzsebet's Avatar
Erzsebet
The story is that we bought it in Poland last year. It is originally from US. There is an original BCM inside but the Polish guy swap the RCM to European. We tried starting the bike in Poland it had sounded as if the engine started. Since this first start the engine is not working. All lights and oil pump and everything is working. After pressing the start button this error code appear. We have checked all wires, relays and we have no more idea what to do.
Old Sep 19, 2020 | 09:21 AM
Erzsebet's Avatar
Erzsebet
Hi, we have solved the problem. The BCM is not working. Does anyone know what is the difference between this module and another one with OEM 69991-11C? Thanks
Old Sep 21, 2020 | 01:14 PM
Zanthamos's Avatar
Zanthamos
The 11C is an updated part.
