No power at Cigarette plug or remote accessory plug?
Old Apr 4, 2021 | 09:29 AM
csaxer08's Avatar
csaxer08
Stage II
Default No power at Cigarette plug or remote accessory plug?
Hey all, I have a 2020 Road Glide and just finished install of Rockford stage 3. However I am not getting power to the amp. After searching everything I found that where you plug the remote wire in is not getting power nor the cigarette plug has power. I’ve also went through the fuses and have power there. Anyone have this issue?
Old Apr 4, 2021 | 09:46 AM
Vernal's Avatar
Vernal
Welcome to the Forum from Utah.
Check your P&A fuse again. It supplies power to the outlets and P&A relay.
Old Apr 4, 2021 | 11:02 AM
csaxer08's Avatar
csaxer08
Stage II
Thank you! I went back through the fuses with a test light and all show power, probably have to take it to dealer and have them fix it. Tested the amp with a jumper wire and it works great! Just don’t understand why I’m not getting power to the remote plug in or cigarette plug.
Old Apr 6, 2021 | 09:16 PM
Zanthamos's Avatar
Zanthamos
Do a DTC check and see if the BCM has detected a fault.
11lofatboy
Apr 14, 2025 09:23 PM
Bikerpipes
May 21, 2018 07:33 PM
Bluraven
Apr 13, 2017 10:03 PM
No U Glider
2014-2024 Touring Models
Nov 29, 2016 08:30 PM
HDSAE60
Engine Mechanical Topics
Mar 22, 2009 11:15 AM
