voltage regulator
Old May 10, 2021 | 04:28 PM
WacoWayne's Avatar
WacoWayne
1st Gear
Default voltage regulator
I have a 2011 Road King. I started it and after about 30 seconds off letting it warm up smoke was pouring out from under the voltage regulator. I checked and I found a large burned spot in the underside of the regulator. The wires and the connectors are fine. I'm curious to get info as to what happened. I don't want to replace the regulator and fry the new one. If anyone can enlighten me as to why the regulator burned up I would greatly appreciate your input. Thanks
Old May 10, 2021 | 09:53 PM
NODYNA's Avatar
NODYNA
Internal short most likely. If the alternator was putting out over voltage the wiring would show signs of over heating and burning. Since you say the wires and plug appear ok that indicates the problem is in the rectifier.
Old May 13, 2021 | 11:23 AM
WacoWayne's Avatar
WacoWayne
1st Gear
Thank you for your reply! That's what I was hoping for.
Old Jun 7, 2021 | 01:07 PM
WacoWayne's Avatar
WacoWayne
1st Gear
More info needed. I replaced rectifier. When I turn on ignition switch I have nothing at all. Is there a fuse or relay I need to check? I replaced rectifier with a genuine Harley rectifier. Thanks
Old Jun 7, 2021 | 06:44 PM
NODYNA's Avatar
NODYNA
You have a 50 amp master fuse under the left side panel. Check that as well as all the fuses and fuse block for corrosion or over heating.
Old Jun 9, 2021 | 09:01 AM
WacoWayne's Avatar
WacoWayne
1st Gear
Replaced main fuse and she started. I appreciate ya'.
Powertrip240
Jun 21, 2015 12:55 PM
Road Star
Jan 31, 2014 12:42 PM
jimsflh
Jun 17, 2010 09:55 AM
3littlepigs
Jun 2, 2008 01:09 AM
gsparesa
Nov 14, 2005 01:29 AM
