Help 2021 Roadglide special.
Need some help, attempting to change out the handlebars. Had a hell of a time running cable through 12” KST Outlaws. But got them through. Started to put everything back together but went to test everything out first and nothing is working but the on/off fuel pump is turning on by the switch. Nothing is turning on except the radio and the fuel pump. No gas gauge no voltage gauge none of the buttons are working the tach or speedo. Only thing is the on/off. About to tear it all apart again hoping I may have forgot something. I didn’t take out any fuses before hand but checked them all and they are all good. Hoping it’s not a short because how convenient both clamshells are shorting. Any advice? Thank you!!
