Headlight issue
Old Aug 20, 2021 | 06:55 PM
hdpratte's Avatar
hdpratte
1st Gear
Default Headlight issue
2005 ultra classic recently I noticed highbeam light indicator was on when on low beam. Checked lights. Auxiliary lights on but no head light. When I switched to high beam the auxiliary lights went dim. I took out headlight and it appears the plug has gotten hot. Do I need to look for a short?
Old Aug 20, 2021 | 08:14 PM
WP50's Avatar
WP50
The auxiliary lights most times are wired to the low beam wire.
If the connection is not solid it can create some heat on that circuit,
What color wire is going to the terminal that is melted?
I got some things to do shortly but these guys are really good to help when they can.
Good Luck WP
Old Aug 23, 2021 | 05:35 PM
hdpratte's Avatar
hdpratte
1st Gear
A black and yellow wire run to the side that got hot.
Old Aug 23, 2021 | 06:03 PM
WP50's Avatar
WP50
Probably only need to replace the connector
You can get a pigtailed connector easy enough, just be sure to solder the connections.
WP
Old Aug 23, 2021 | 06:22 PM
hdpratte's Avatar
hdpratte
1st Gear
Thank you so much!
Dennis O'Connor
May 19, 2020 11:47 AM
City Worker
Mar 20, 2018 05:32 AM
varider12$
2014-2024 Touring Models
13
Aug 2, 2017 11:31 PM
SecondChance!!
Panhead
Apr 20, 2011 08:55 AM
rcc
Aug 7, 2008 11:31 AM
