Rear lamp flickering RK 2002
Old Apr 23, 2022 | 04:15 AM
Steinom's Avatar
Steinom
Stage III
Default Rear lamp flickering RK 2002
Hi.
My rear lamp has start flickering, only when the engine is running. Maybe a loose connector? Where to start looking?
The bike is a RK 2002 Custom Classic.
Old Apr 23, 2022 | 06:04 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Rear lamp? Which one?
If it is the taillight, look at the front running lights, are they flickering also?
Always do the simple, cheap stuff first.
What is the simplest, cheapest thing to do? Check the bulb.
Check the connector for the rear lighting, make sure the pins and sockets inside the connector look good and none are pushed out of the connector.
Old Apr 23, 2022 | 03:18 PM
Steinom's Avatar
Steinom
Stage III
The problem is solved.
I opened the tail light and all looks brand new! But the bulb had bad connection in the socket, a splash with elektrospray solved the problem.
Old Apr 23, 2022 | 03:48 PM
TwiZted Biker's Avatar
TwiZted Biker
My first go to's with lights or ignition issues is check for dirty or loose connections and grounds.
Magnut1
Oct 29, 2018 09:48 AM
monumaker
Mar 20, 2013 10:27 AM
thetileman
Jun 20, 2010 02:18 PM
torq
Jan 31, 2008 11:38 PM
movintons
Jun 6, 2005 04:30 PM
