"Floating Tach"
Old Nov 1, 2022 | 03:25 AM
Shables's Avatar
Shables
Stage III
Default "Floating Tach"
I just have to put this question out into the ether because I've never seen this before.
I was at the end of a hundred mile putt sunday, through the rolling hills of Western Wisconsin when my motor got torqued down by a steep incline and I wasn't down shifted enough so my motor almost chugged. I have a 98 Ultra,by the way.
Anyway I got to level road and was tooling down the road and my motor skipped a beat. I looked at my tachometer and it was floating between 2300 and around 1900 rpms, not running on a single number, but floating over it and below it. Has anyone ever seen that or heard about it? About 20 seconds later I lost all power to everything except Speedo light and rear fender marker.
Old Nov 1, 2022 | 05:51 AM
Hey Man's Avatar
Hey Man
I'll be keeping an eye on this because the same thing happened to my 93 FLSTC two days ago!
Old Nov 1, 2022 | 12:06 PM
bustert's Avatar
bustert
cannot say anything for the loss of power but the tach and speedo can be skewed by vibration. did you try a power recycle??
i have an 01 sport and if it take it to the limits, both or and/or will act up. these things are digital now and they are stupid when it comes to position. they use a frequency to voltage generator to output a voltage level supposedly calibrated to the speed/rpm, if you move them via vibration, they do not know and will read off the wall numbers, a power cycle allows them to reset to zero.
Old Nov 5, 2022 | 11:00 AM
larsfum's Avatar
larsfum
I have heard that a failing voltage regulator will effect the tach like that. Is your 98 EFI? If so load test the battery and pull any trouble codes.
Old Nov 6, 2022 | 07:06 AM
bustert's Avatar
bustert
i can see that IF the diodes are failing and you get high ripple through the regulator. if your meter has frequency function take a reading throughout the rpm range. some ripple is permissible since the battery acts like a giant filter capacitor. another tell is flickering in the lights, if high enough, it will blow the lights.
Old Nov 6, 2022 | 07:19 AM
im's Avatar
im
Keep in mind that we can not see the bike.
We have no idea of mileage, condition of bike or any changes from factory.
We also have no idea about ownership history in order to better gauge when bike last worked correctly.
Taking a guess that bike is fuel injected too.
Trying to decipher your description....
It reads like you were in the incorrect gear while going uphill.
When the road became flat the bike misfired?? (guessing you mean briefly turned ON & OFF) and the tachometer responded by bouncing the needle.
Then you lost engine power ? or electrical power?
Did the bike restart?
It could be something simple like loose battery cables (check all 4 ends of cables).
YES...four ends...the two at battery and the other ends.
Old Nov 6, 2022 | 07:24 AM
im's Avatar
im
Consider the review of the below copy/paste.
Maybe print it and place in saddle bag.
Items for touring of that era:
1-COMMON..If fuel injected...Two fuel hoses under tank leak after 10 years. Harley $$$$$$$, Goodridge HDFL005 under $160 USA dollars or LESS total for BOTH if you check google .
The Goodridge lines are less than half the price of the Harley parts and are of good quality.
2-COMMON..If it has a fuel tank mounted gauge..speedometer LCD (odometer screen bleed). requires replacement when unable to read miles ridden. NOT PLUG AND PLAY LIKE NEWER ONES. You can get a sub-harness wire assembly from J & P cycle catalog and then use a 1999 speedometer plug and play speedometer.
Easy changeover with no splicing of wires required. Old speedometer is a different manufacturer from the newer ones.
Note that mileage is stored in speedometer itself not in ECM.
Some folks send old speedometer out to specialty shops in order to change-out the LCD.
3-COMMON..Cam position sensor...very difficult starting, lots of cranking but does not catch. A lot of cranking and no start then you wait a second and a quick tap to start button and it starts with very little cranking…look for visible goo (beige) leak under timer cone (right foot) at black wire exit from bottom of cone…You will have plenty of warning…dozens and dozens of difficult starts.
4-CRANK position sensor by oil filter (RARE) but if you use a power commander the signal must be 100%..This is very rare.
5-(MEDIUM COMMON)Tank liner releases at middle section near fuel pump..blocks flow of fuel..loss of power, slow down and piece moves from fuel inlet so bike is OK but then becomes trapped again so cycle repeats.. FREE REPAIR..open gas tank access lid, drain fuel and clean piece out..I would carry the little bit required to remove screw..The book says you need to replace the one time use screws but if you are careful and replace in the same location it will be re-usable at least one time..
6- VERY COMMON...ENGINE TEMPERATURE SENSOR...very common, general rough riding as bike bucks from cold to hot rapidly..$100 part…As an emergency by-pass just disconnect the idle control behind air filter when bike is off/at rest..You will need to hold throttle.
7- Bikes that are pressure washed or in snow conditions with salt roads or people that added a power commander and destroyed the rubber boot at ECM..GROUNDING PIN ON ECM becomes corroded and requires cleaning.
8-The little chrome cover cap thing with the allen bolt on the starter end will get loose one time and you will chase the rattle a long time until you figure out that under the cover is two 0.15 cent nuts and one is lost.
***-The shift linkage ends SUCK on all harleys and you need to change those yesterday to heim joints look on ebay if on a budget for: Heim Joint Rod End 5/16" with bolts for Harley Davidson as they should be about $10-$15 delivered for both.
****VERY IMPORTANT...THE CRANK POSITION SENSOR USES AN INSERT TWIST AND LOCK CONNECTION. MAKE 100% sure it is tight, zip tied and secure and then tie it one more time.. Located at throttle side of frame behind the PAINTED plastic side cover by seat (remove cover) and hidden by the triangle portion of frame..connector is black and about 2 or 3 inches long and the thickness of a fat pencil.
That thing had me scratching my head for a long time trying to chase an intermittant cut-off over bumps. Side of the road frustration thing..Many shops are unable to identify the simple problem while others waste your money by replacing it when it was only loose.
THE PARTS ARE READILY AVAILABLE for this bike with the exception of the gas tank from either the dealer or aftermarket.
I would imagine you have the service book or will get the service book for this bike from Harley for 99483-98 . Finally get the book read chapter 9. You can review check engine codes with no tools by following a simple sequence.
I would review the fuel lines. If you do NOT have the goodridge lines HDFL005 then I would consider carrying some in your saddle bag. Rarely does a dealer stock the Harley ones.
Additional notes:
Consider using regular Dyno oil as the synthetics are too good at locating leaks.
Check the allen bolt at the transmission shift lever. The shift lever that attaches to the transmission spline/shaft. People forget to check that allen/hex bolt and then the splines on the lever get chewed.
Shaft is harder than lever so the lever will strip. Major labor to remove the outer primary, inner primary, and clutch hub just to replace the lever on that year of bike just because someone did not inspect that allen/hex bolt.
The throttle PULL cable might eventually give-up the throttle cable end ball. My cable had a few strands broken off at the little ball inside throttle clamp. It eventually snapped while on a road trip. Required switching return for pull cable in a parking lot. I would review and consider changing Throttle, Brake and Clutch cable if they are original.
There is a bracket 65619-98 called something like exhaust bracket tab located right at top of starter. Supports rear cylinder exhaust pipe right at starter. It sometimes breaks after 20 years right at the “L”..right at the clamp . Most people fail to look at it until further more costly problems develop instead of addressing the under $10 USA dollar part and saving future headaches and cost..
That bike era does not due well with rear swingarm lowering blocks. Check for and consider removal of rear lowering blocks if someone used them. They increase probability of rear swing arm crack since they alter shock angle. Blocks change in shock position at bottom and that appears to stress swingarm in my opinion.
Jersey Drew
Jun 20, 2021 07:29 PM
Dans03RKC
Jul 26, 2012 06:07 AM
ambulldog1234
Dec 2, 2011 10:32 PM
xbrashearsx
Nov 5, 2011 02:31 PM
wackykid13
Sep 16, 2011 12:07 AM
