Led tail light
Old Jun 5, 2023 | 08:41 AM
Qwik 1's Avatar
Qwik 1
Default Led tail light
I changed to a led tail light now do I need to run a smaller circuit breaker?
Old Jun 5, 2023 | 08:49 AM
Jackie Paper's Avatar
Jackie Paper
My opinion is the circuit breaker is designed for the wire size. The bike is protected from LED by the housing of the light.
Would not hurt to add a inline fuse if other components are on the taillight breaker.
Old Jun 5, 2023 | 10:20 AM
07UltraGuy's Avatar
07UltraGuy
What are you asking?
A circuit breaker is essentially a resettable fuse.
The LED taillight will draw significantly less current than the original incandescent bulb, so there is no reason to alter the wiring or circuitry simply because you’ve upgraded the taillight to LED.
What you may be referring to is a “load equalizer” (resistor) that needs to be added when converting to LED turn signals.
This is because the load of the LED bulb is low enough that the circuit configuration needs to closely match the original circuitry in order for the new bulb to work properly.
Old Jun 5, 2023 | 01:05 PM
Qwik 1's Avatar
Qwik 1
Thanks, I have changed to led turn signals and tail light. I didn't use much of the original tail light/ blinker wire. So what my question is with smaller gauge wiring and leds pulling less load to protect it would I need to lower the circuit breaker rating? I am using a electronic module for the blinkers and also using one on the brake light that flashes 5 quick times and then stays on.
2018+ Softail Models
17
Feb 11, 2022 11:03 PM
taz944t
Oct 9, 2018 11:30 AM
DugzKine
Nov 5, 2016 09:30 PM
taterbum
Electrical/Lighting/Alarm
Jan 17, 2016 09:15 AM
jtmurph00
Aug 7, 2008 01:35 AM
