sylvania load equalizer not working.
Old Jul 12, 2023 | 08:54 PM
section8joe's Avatar
section8joe
Default sylvania load equalizer not working.
I'm working on a 2002 sportster. I'm trying to wire up i
nline load equalizers nline load equalizers
on LED turns, When i have the original front and rear turn signals wired up everything works normal. I'm trying to remove the front turn signals and just run LED rears and when I wire up the signal with the load equalizer the signals stay solid. I somehow tested the equalizer a few days ago and I got the signal to flash properly using on load equalizer on the rear and the front signals completely disconnected but I can't get them to work again, they just stay solid. Any advice? Are the equalizers directional? Do I need to ground the actual metal part of the equalizer(although i highly doubt this is the problem) The equalizer kit comes with those clip on connectors that i'm not using. Could that be my problem?
Old Jul 14, 2023 | 08:08 AM
bustert's Avatar
bustert
easy peasy
vtchopperdude
Oct 27, 2018 06:44 AM
jambo1989
Jan 17, 2017 08:33 PM
_wcc_
May 3, 2015 10:50 PM
sdeck86
Feb 22, 2015 04:53 AM
dieselweasel
May 17, 2008 08:36 PM
