CVO dash lock switch resister
I thought the same thing when CC first posted, the term "terminating resistor", made me think Can Bus resistor.
The hard part for me was finding information on SE, Drawings and manual supplements, but one FB Goup had a few.
CaptCrunch is looking for the resistor pack at connector 200. The switch pack sends P&A power to the resistor pack, depending which resistor the power goes to, (lock or unlock), the current going to the IM is different. IM gets the "signal" from the Resistor Pack and communicates to the BCM on Can Buss and a signal is sent to lock or unlock relay.
I don't see any resistor in the fuel pump or level circuit, but the resistor pack PN does mention sportster fuel level.
Here are some schematics of 2023 CVO- SE and 2020 Touring. I just don't see a resistor in the fuel level circuit.
CVO
CVO
CVO
2020 Touring
2020 touring
CVO
CVO
CVO
2020 Touring
2020 touring
I was intending to say that I agree with you, and your findings match that of both my own research, as well as that of my local dealerships parts and service departments, whom Ive interrogated intensely on finding this part. The closest anyone can find is the fuel resistor.
Ive offered to pay the local techs to investigate a used CVO on the floor to determine a part number and they graciously offered to investigate free of charge when they have a free moment.
I wouldn't call it a fuel resistor. The diagrams I posted shows the Resistor Pack @ connector 200, the parts catalog shows it in the same area, so I think it's a safe bet that it's the one you're after.
i think its possible that the IM needs to be flashed to support this functionality since it is responsible for translating the input from the locks to a CAN signal and requesting that the BCM fires the outputs.
If it does I will have to take it to the dealer who has generously offered to do any flashing related to this project for free. Ive already flashed the BCM to enable the power locks and they are fully functional with the key fob, but neither my Centurion nor my Texa gives an option to flash the IM for that particular function.
