I have a 2026 Breakout that I just did a bar swap on. I followed Harley procedure for removing the main fuse. After finishing the installation I followed procedure for reinstalling the main fuse. When the ignition is turned on the instrument cluster just cycles on and off repeatedly in a loop. I checked for piched wires and found none. Everything seems to be plugged in correctly. Any advise besides tow it to the dealer and pay hundreds if not thousands for diagnostic and repair?
I would double-check all wiring connections that you unplugged and look for any pinched wires in the handlebar hand controls. Basically, just double-check every wire you touched.
Thanks for the reply. I did go back and realized I had plugged controls into the wrong port. Switched it up and BOOM, we have everything working as it should.
