coil relocation
Old May 10, 2009 | 06:43 PM
niczumbo's Avatar
niczumbo
Default coil relocation
well i tried in the softail spot,so now ill try it here.i have a 07 standard and i want to relocate my coil to the horn spot.anybody got any ideas? my coil will not bolt up to the horn cover cause its different than a 06 coil(which will) i already moved the horn to the front downtubes and i know i have to spice the coil wires so they reach.i really didnt want to give Roland Sands or Yankee Engineuity 200 bucks for thier custom brackets
Old May 10, 2009 | 09:43 PM
colt_357's Avatar
colt_357
So do you have any of your own Yankee Ingenuity ? If so you could fab up your own. Here look at mine for ideas. This is home made out of 6061 billet and has my ignition/key switch which is from a fork lift.Everything was drilled and tapped and has allen set screws to hold coils. But you will have to make your own set up for you application.
Old May 11, 2009 | 05:43 PM
niczumbo's Avatar
niczumbo
nice setup ,very well done but whats the point of two coils? and i have been thinking of just cutting and fabing my old set post bracket and see if i can make that work in the horn spot
Old May 11, 2009 | 06:21 PM
colt_357's Avatar
colt_357
I have Crane HI-4 single fire race ignition on S&S 96ci. Two cylinders two coils. Ignition fires to both coils then to spark plugs. Better performance this way.
Bonaro
Mar 17, 2014 08:14 PM
$eventy2T
May 15, 2013 05:48 PM
NativeTexican
Jun 4, 2012 08:47 PM
rlo1
Apr 5, 2012 01:29 PM
mopar360
Sep 26, 2006 12:14 AM
