GPS Power Connection
Old Mar 13, 2010 | 09:03 PM
Glenno's Avatar
Glenno
Default GPS Power Connection
Where is the best place to power a handle bar mounted GPS unit on a Street Glide with a Bat Wing fairing? Is there a good place under the Bat Wing or do you run wire directly to battery? Or somewhere else?
Old Mar 14, 2010 | 07:11 PM
nocarb's Avatar
nocarb
I used the 2 wires that are taped to your headlight wires. They are sideways looking spade connectors.
Old Mar 15, 2010 | 11:01 AM
UltraNutZ's Avatar
UltraNutZ
nocarb is right. run your wires down your left handlebar (tiewrapped) through the handlebar hole in the fairing. right behind the headlight is a factory power source. One wire is orange/red, the other black. Obviously orange/red is the + side and black is the ground.
Old Mar 15, 2010 | 07:32 PM
Glenno's Avatar
Glenno
Thanks fellows. I tapped into the cigarette lighter wires before I read your posts. But know that I know those wires are there could I use them for lighting? Also are those wires connected to a switch?
Old Mar 16, 2010 | 08:48 AM
UltraNutZ's Avatar
UltraNutZ
they are in fact an unswitched circuit. Always hot!
grbrown
Apr 28, 2016 07:43 AM
mcso
Dec 26, 2014 08:30 AM
PDDGM
Mar 22, 2012 07:57 PM
Volfan615
Oct 28, 2008 01:09 PM
petemac
Jun 6, 2008 12:57 PM
