Throttle cable hot when starting
Old 04-23-2013, 07:07 PM
Deebs312's Avatar
Deebs312
Deebs312 is offline
Stage II
Default Throttle cable hot when starting
I`m new here and thanks for letting me join this forum. I own a 1998 Road King. The other day I wanted to go out for a ride but the bike wouldn't start. When pushing on the start switch I noticed that my throttle cable was hot and started to smoke. For s**ts and giggles I put a volt meter on the throttle cable while turning over the motor. It jumped up to 8 volts before I let go of the switch. I know that is not supposed to happen. Any help will be greatly appreciated.
Thanks
Adam
Old 04-23-2013, 08:32 PM
Deucedog's Avatar
Deucedog
Deucedog is offline
Welcome Deebs,
Sounds like you may have a hot wire shorted to your cable. I would start trouble shooting in the switch housing.
Old 04-23-2013, 09:04 PM
mack42b's Avatar
mack42b
mack42b is offline
You probably have a faulty ground connection on the engine and the throttle cable is doing some of the grounding when you crank the engine. Check and tighten all of the engine grounda and your problem will probably be solved.
Old 04-23-2013, 09:11 PM
Vincewd's Avatar
Vincewd
Vincewd is offline
I agree with Mack, Your cable is acting as a ground, check your ground cable.
Old 04-24-2013, 07:16 AM
Deebs312's Avatar
Deebs312
Deebs312 is offline
Stage II
Thanks for the replies. I can only see one ground for the engine. The one to the starter. Is that the only one
Webdude75
12-05-2013 05:05 PM
bgajms1215
12-14-2011 02:57 PM
Viejo
06-22-2009 12:58 PM
Ultra RB
02-09-2008 11:31 PM
wlbowers
03-10-2007 09:08 PM
Quick Reply: Throttle cable hot when starting
