Starter Issues
Old Aug 27, 2013 | 10:57 PM
RobertMurray's Avatar
RobertMurray
Stage II
Default Starter Issues
I have a 2011 FatBoy Lo and am having starter issues. I can hear the starter spinning when I press the start button but the starter is not engaging the engine and cranking the engine over, only spinning. When this problem started, I tried to push start the bike and found the following issue,( issue #2 ) With the bike in neutral the bike rolls freely. When I pull the clutch lever and shift the bike into 1st gear and keeping the clutch lever pulled, the bike no longer rolls freely. This second issue is while the engine is not running. I need help, please
Old Aug 28, 2013 | 04:22 PM
grbrown's Avatar
grbrown
Hi Robert and welcome to HDF. I recommend you call in the Softail forum where you should get a lot more hits and help. They are far too busy over there to call in here! Hope you get sorted out soon.
Sagebrush6
Jun 6, 2015 01:21 PM
RobertMurray
Aug 29, 2013 08:12 AM
Randall
May 13, 2011 11:51 AM
paco ritter
May 7, 2009 02:34 PM
traxsmax
Ironhead
Aug 31, 2006 11:15 AM
