Running lights
Old May 14, 2014 | 03:47 PM
nthere1's Avatar
nthere1
Default Running lights
My problem
Running lights are not working. The turn signals, brake lights hazard lights work. Even when the alarm sets the lights will flash as normal.
What I have done.
I had custom dynamics led lights with load equalizer. I disconnected it and put everything stock back including bulbs same issue. I have checked fuzes well what I can see.
Issued started when I went to get a state inspection and tech advised me the left side turn signal was out. Went home opened the bullet style housing full of water and corroded. So I just replaced the housing. Still had same issue stated above.
Any help where to start. I have tour the front fairing off and I'm not getting power to the plug for running light. I'm no tech when it comes to electrical. So please insult my intelligence, I'm humble. Will be looking for more fixes and waiting for you gurus to respond to my post
2011 flhx street glide is the bike.
Old May 14, 2014 | 04:29 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Change the "Lights" fuse.
If that doesn`t fix the problem, check voltage at the fuse to make sure the fuse is getting power.
Old May 14, 2014 | 04:38 PM
nthere1's Avatar
nthere1
So after hours of checking fuses tearing the whole bike apart. I must have missed that fuse with the fuse checker. Thanks for insulting my intelligence. But at least I I got some personal time with my bike. You can't fix stupid. Thanks
65Chevelle
Electrical/Lighting/Alarm
May 13, 2019 01:00 PM
sB43
EVO
Jun 17, 2018 05:31 AM
kingroad99
Jul 27, 2011 06:13 PM
kingroad99
Jul 15, 2011 10:25 PM
kingroad99
Jul 15, 2011 10:00 PM
