front turn signals 2003 flstf
Old May 18, 2014 | 11:38 PM
punkaa88's Avatar
punkaa88
Stage III
Default front turn signals 2003 flstf
Hi Big newbie here, and may have skipped a intro and maybe others but in a bit of deadline to get through import into Canada inspections. so here goes,
Bought a 2003 in arizona, that has no front or rear turn signals, found the plugin for the rears in stop light housing, but previous owner installed beach cruiser bars, with harness inside, turn signal indicators are working but cannot locate the left and right 3 wire feed harnesess from the turn signal module on rear front fender that as per wiring schematic, run up front to operate the turn signals,
previous owner also spliced in the l and r switch harnesess to inside the freight train headlight, just no sign of front turn signal harness, have looked every where in can under fuel tank, but no sign of them, I beleive there is a connector 31 between the module and the turn signals as per schematic which i,m thinking is under the tank, but just cannot believe he would have removed the tank to eliminate the front turn signal wiring, since he cut the switch harness and spliced it to accomodate the l and r switch controls. no sign of tank being removed since manufactor, only 5300 miles on it,
Don,t want to remove the tank in not required but now stumped, maybe missing something? any ideas, and could anyone tell me if this 31 connector ir under the tank, Thanks Andy
Turbinesaint
Nov 2, 2015 08:45 PM
rlchristensenmd
Oct 23, 2015 06:57 AM
Valdemar
Dec 19, 2014 01:59 PM
KEC_FXDX
Oct 26, 2010 09:17 AM
Meat Head
May 9, 2010 06:47 PM
