Probem with my electrical system
Old May 27, 2014 | 01:51 PM
imjake92's Avatar
imjake92
Stage III
Default Probem with my electrical system
Hey guys,
New to the forum, and I am in need of some seasoned riders to give me some advice. I have searched all over the forums and haven't found an answer.
I own a 1985 Harley FXSTS Softtail with an EVO motor, and up until a week ago I had no issues with it. Then, on a rather short ride to the local bar, my bike just turned off as we were turning into the bar. No lights, no ignition, no power, no anything. The bike was dead. I pulled the seat off, moved some wires and in general just waited a minute, and then she fired right back up. It was fine the rest of the night.
Then, the next day, I was on a ride with some buddies, and we stopped at a stop sign. As soon as I went to accelerate, the bike shut off again. Same issue. No lights, no power, no ignition. I did the same thing as last time, but now I still have nothing. I pulled the battery out and checked it, and the battery is fine. It holds power and charges up without issue, and is currently sitting on the tender. I am unaware of where fuses or circuit breakers, depending on the bike, would be. Any ideas what the hell is wrong with it or where I should start to look? Please be as descriptive as possible as to where I should check and what to look for.
Thanks for helping out the new kid!
Old May 27, 2014 | 02:00 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Could it have been battery connection. Probably will go away now that you have reconnected. The light and the main start are separate breakers. So when it all went, it was the connection.
Old May 27, 2014 | 09:35 PM
radd75's Avatar
radd75
Stage III
I have replaced stator volt reg new battery and the battery still wont charge
1200c sporty
Old May 27, 2014 | 11:02 PM
Bluetoys's Avatar
Bluetoys
It sounds like a loose ground wire.check both battery wires and clean them, if necessary.
Follow the negative wire to the frame. If it isn't loose, remove it from the frame and see if it needs to be cleaned.
Old May 27, 2014 | 11:05 PM
soft 02's Avatar
soft 02
90% of elec issues are a bad ground.
Old May 28, 2014 | 05:07 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Since you are losing all electrical, the problem is probably a connection to the battery or somewhere between the battery and the ignition switch. Check the connection at the main breaker, it is mounted to a copper strip at the positive post on the battery.
The tan wire connected to the main breaker supplies all power to the ignition switch, check the connection at the ignition switch. It is not uncommon for connections to come loose or break at the ignition switch.
I don`t agree with that, but I do agree that 90% of the people think that 90% of electrical problems are bad ground...
Old May 28, 2014 | 05:12 AM
Dan89FLSTC's Avatar
Dan89FLSTC
1200c sporty
Start your own thread...
We`re trying to help imjake92 here.
Old May 28, 2014 | 06:44 AM
soft 02's Avatar
soft 02
Yea but it gets them to check all the grounds and helps to find the problem.
Old May 29, 2014 | 06:47 PM
imjake92's Avatar
imjake92
Stage III
Alright, so I followed my wiring and found a bad connection on one of the neutral sides, as well as some corrosion. I'm going to clean everything up overnight and put it back together. I'll let you guys know what I find out. I appreciate the diversity of responses and the swiftness you guys got back to me. I'll let you guys know what I find.
Old May 30, 2014 | 06:26 PM
imjake92's Avatar
imjake92
Stage III
Well, no go guys. I put the new connectors on the two bad wires and still nothing.... Next step?
