2000 1200 xlh
Old Jul 21, 2014 | 07:09 AM
jopeck11's Avatar
jopeck11
5th Gear
Default 2000 1200 xlh
Washed and blow dried the bike, rode after, everything was fine, turned off bike and now when key is turn on, the only thing than goes on is the speedometer light( no headlight, no waring lights, no starter action, check fuses all good, no signal lights, brake and four ways will work, replaced battery,
Old Jul 21, 2014 | 07:13 AM
Iceman24's Avatar
Iceman24
Something got wet...look @ wiring harness(es) for frays, breaks, wear, etc. Also, ensure you have "both" ends of battery cables clean/tight.
Old Jul 24, 2014 | 03:11 PM
jopeck11's Avatar
jopeck11
5th Gear
Default problem solved
Ignition switch is bad, hot wired and everything works fine, ordered switch from dealer, washing had nothing to do with problem. I hope this helps others
SaltLakeSmitty
May 27, 2017 08:42 PM
CScobs
Electrical/Lighting/Alarm
May 18, 2015 06:36 PM
jopeck11
Jul 24, 2014 03:01 PM
kong123
Feb 3, 2013 08:51 AM
waterman7474
Feb 20, 2007 03:35 AM
