Cam Install Disaster
Old Oct 1, 2014 | 12:06 AM
rideamap's Avatar
rideamap
Default Cam Install Disaster
So I decided to throw in some SE255 cams into my 96" Dyna. Read lots of articles, studied the manual had some experience digging into my sportster motor to convert to a 1200 before with no problems so I thought this project was doable. Boy was I wrong.
Now let me just say that this was not difficult. I just screwed up and wanted to share this so no one else goes through what I did.
Anyways so what happened was I disassembled everything I needed and I was at the halfway point. I went to pull the old bearings with the bearing puller tool. This is where I should have stopped. It was late at night, I was tired from taking everything apart and I should of put everything away for the night but I was too damn excited so I kept on. But for some reason I could not pull the old bearings out. I kept turning the puller with the wrench not knowing I was tearing apart the old cam bearing!
The next morning when I came out to continue where I left off I found fragments of the old bearing in pieces. I was able to collect all but three bearing rollers which fell into the crank case. Now my bikes in the shop for open heart surgery (getting the cases split to retrieve the pieces).
Moral of the story I don't regret trying to do it myself but a simple mistake cost me a lot more than I had planned on for this project. Anyhow I hope when its all back together the cams will make me forget!
Old Oct 1, 2014 | 03:51 AM
Crex39's Avatar
Crex39
Working while tired and rushing are the enemies who don't do this kind of work for a living.
Old Oct 1, 2014 | 06:38 AM
prodrag1320's Avatar
prodrag1320
not a real good idea for us who do it for a living either
Old Oct 1, 2014 | 09:05 AM
djl's Avatar
djl
Some have been successful retrieving missing rollers from the crankcase by trolling with magnets and avoiding the "open heart surgery".
Old Oct 1, 2014 | 09:07 AM
1BRAVO9's Avatar
1BRAVO9
Thanks for the heads up, I hope everything works out for you.
Old Oct 1, 2014 | 11:01 AM
Str8six's Avatar
Str8six
I don't work on these things every day but i have found that the cheaper cam being puller seems to damage before it pulls on those bearings. After my first one i started packing the old bearing and outside surface of my puller with heavy grease so if this does happen the needles will stick rather than fall into the crankcase.
Old Oct 1, 2014 | 02:16 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
And as Kirby said even for those that do it day in/day out, and have for years, the tired and rushing thing, is not good.
Scott
Old Oct 1, 2014 | 04:12 PM
Felix 808's Avatar
Felix 808
I've often found thoughout my life that being in a hurry gets you nothing but trouble in a hurry. Thank you for sharing your troubles to help others advoid the same mistake. Goodluck with your repairs
Old Oct 1, 2014 | 11:24 PM
HD Pilot's Avatar
HD Pilot
OK, you were tired and rushing but what exactly was the mistake made? Was it a cheap tool or did you install it wrong into the old bearing?
Old Oct 1, 2014 | 11:57 PM
rideamap's Avatar
rideamap
Well what I did wrong was I was turning the puller the wrong way. I didn't notice because I had the 4 thumb screws screwed down so the support plate wasn't moving but it would have been moving outward if the screws weren't screwed down and I would have noticed then. There is another type of puller with a cylinder and two nuts that you tighten together. The one I had was a puller/installer combo off ebay. The quality of the tool was not the problem, it was me. After I had realized that I totally messed up I used the tool the right way and it worked fine. I pulled out the old bearings no problem. I ended up putting the whole thing back together so I didn't have to bring the bike to the shop in pieces. I'm no mechanic (obviously). I'll admit that but I've saved lots of money in my life doing things myself. More than enough to pay the shop for this screw up. By the way if anyone is curious how much it cost to split the cases its $90/hr @ 10-11 hours. Ouch is right.
