88TC rocker shafts
Old Oct 28, 2014 | 07:03 PM
Am4wag's Avatar
Am4wag
Default 88TC rocker shafts
In an '06 RK.....rear rocker shaft support plate JUST won't come out.2 left bolt heads are hard against frame and JUST not up out of the hole.I've considered grinding the heads of them or cutting them.Is there any "magic twist" or are these going to have to be ground/cut.Just hate to have metal dust falling.
Old Oct 28, 2014 | 07:14 PM
soft 02's Avatar
soft 02
Should come out just fine. Are all 6 bolts loose? I have to rock my support plate sideways to remove those 2 boldt. Mines a softail but should be about the same.
Old Oct 28, 2014 | 07:30 PM
Am4wag's Avatar
Am4wag
All are out except left side 2 rocker support plate and one breather plate bolts.Don't want to break anything.
Old Oct 28, 2014 | 07:32 PM
soft 02's Avatar
soft 02
Wonder if on touring bikes you need to loosen the motor mount.
Old Oct 28, 2014 | 09:27 PM
djl's Avatar
djl
It is a tight fit but it will come out. The first time I pulled the rear rocker support plate on an early FL model a few years gone by, I swore it would not come out. My better half heard me cursing the plate, the bike, my two dogs that were watching the struggle and came out into the garage to inquire what was the problem. She took a look, reached in and extracted the support plate in about 2 seconds.
As you have done, remove all the bolts that you can and remove it from the right (brake) side of the bike; it's easier from that side. If you still can't get it out, get another pair of hands and a length of 2x4 or lever of choice and have someone use the lever to push the motor down in the frame. There is enough give, maybe 1/4"-3/8" which is all you will need to extract the support. Once you have done it, it will be easier the next time. Good luck!
Old Oct 29, 2014 | 01:08 PM
Am4wag's Avatar
Am4wag
New to rubber mounted motors,wow thanks for the tip dgl....NOW for the question/heads up for the day-rockers have .014"-.016" end play,which is below the .025",so I'm assuming they're good to go back together (?).
Old Oct 29, 2014 | 02:59 PM
djl's Avatar
djl
IMHO, shimming at .014"-.016" is not worth the trouble but if shimming to .004"-.006" makes you feel all warm and fuzzy, do it but do it right. The right way would be to chuck the rocker arms up in lathe and true up the ends so they are at 90* to the centerline, re-install and re-measure and use the thickest shim you an get but don't use anything less than .010". Shim to the thrust side; i.e., exhaust to the right (brake) side and intake to the left (clutch) side.
The reason I say it won't make any difference is that the rocker arm is pushed to the thrust side on start up and pretty much stays there; doesn't bounce back and forth. I would not waste the time.
ROCKOUT Rocker Products
Nov 22, 2020 04:47 PM
ride2tires
May 10, 2011 03:09 PM
VTwin-Goodies
Jun 2, 2009 10:03 AM
Marco76
Jul 12, 2008 11:33 PM
fxstbharley2008
Mar 20, 2008 08:06 PM
