Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Would like the heads on the above motor worked who do I send them to ??? Also a cam too !!!
You have a ton of choices, I have used 110 heads reworked with great results from (in no particular order) WFO Larry, HD street performance(Don Dorfman) R&R cycle and my own head porter Bob D.
Just beware of the pushy porting salesmen
Tuner to use ??? The 2011 cvo street glide has a 32 tooth on the tran ??? I had a pro-street with a 115 TP motor with baker tran. drop 3 teeth down I think maybe 4...been few years back...it bad torque big time then.
