Dyna 103 cam suggestion
Old Feb 26, 2015 | 08:56 AM
0ldhippie's Avatar
0ldhippie
Stock heads max out around 100hp so your 100/100 goal is a reach without headwork but 95/110 is very realistic with a cam swap along with proper exhaust, a/c and tune. I'm a fan of Andrews 57 in stage 1 103s.
Old Feb 26, 2015 | 09:01 AM
98hotrodfatboy's Avatar
98hotrodfatboy
The 57, 555, 777, really do require a bit more than stock compression to make them come alive but the 222, mr103 and 48h or even the 204 are probably gonna be your best bet. For stock that is....
Old Feb 26, 2015 | 03:58 PM
usmcbuck's Avatar
usmcbuck
Another to throw in the mix, Red Shift 527.
Old Feb 26, 2015 | 04:10 PM
cdonis's Avatar
cdonis
I like my cam set, but the tman 555 torqster looks great as a 103 bolt in. Remember as a bolt in there are probably at least 5 cams that are right there Neck and neck. I went with s and s products. There is no magic cam, but there are a handful that work really well for your application. Ask you tuner what he likes the best After you narrow it down to 2 or 3. A great tune will make or break you.
2012ElectraGlideClassic
Engine Mechanical Topics
30
Jul 7, 2014 03:00 PM
thewholehog
Exhaust System Topics
19
Feb 9, 2013 06:57 AM
103 st bob
Sep 28, 2010 10:43 AM
roadroids
21
May 15, 2008 11:15 PM
marty44
Mar 20, 2008 02:36 PM
