88 cam question
Old Mar 5, 2015 | 08:22 PM
bigdog1949's Avatar
bigdog1949
Default 88 cam question
Have 06 flhtc 88 ,does it have hyd or spring cam tenisoners, and cage bearings or koyo timkin bearings
Old Mar 5, 2015 | 10:59 PM
Stych's Avatar
Stych
Pretty sure only the only '06 that has the hydraulic tensioners is the Dyna, as in "(except 2006 DynaŽ models)". As far as the bearings, plan on replacing them.
Old Mar 6, 2015 | 01:49 AM
Am4wag's Avatar
Am4wag
You have sprung tensioners.All the cam bearings are flat/roller/caged type-not tapered "Timkin" type.
Old Mar 6, 2015 | 05:54 AM
bigdog1949's Avatar
bigdog1949
Default Cam bearings
Thanks ,didn't want to tear it down for nothing !
Old Mar 6, 2015 | 12:46 PM
hobobiker's Avatar
hobobiker
I think you might mean Koyo "Torrington" style bearings, which have the roller-to-roller interface without the metal cages in-between. Timkins are actually a tapered-style bearing like you find in fork necks and the older bikes used them in the wheels.
Regardless of what you meant, you have the caged INA bearings and I always replace 'em if I'm in there for any reason.
Good luck!
Hobo
Old Mar 9, 2015 | 02:58 PM
jamess71's Avatar
jamess71
I have the same bike and just did the cyco tensioners along with the bearings too.
bigdog1949
Mar 5, 2015 08:06 PM
johnod
EVO
Feb 21, 2015 11:17 PM
Strahley
Engine Mechanical Topics
May 21, 2014 06:00 PM
notarheli
May 1, 2008 07:36 PM
edsaws
Feb 6, 2006 08:37 PM
