Need Advice
Old Mar 23, 2015 | 01:31 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Originally Posted by mikesroadking
Sprayed around head gasket and manifold with carb cleaner, no leaks. Running Stage 1 air filter, and I'm told the pressure is well above 100. What I really neded to start with was another set of the HTCC pistons. It sounds great and runs strong I just hate hearing it at a stop light.
Let me rephrase my question. What brand and style AC do you have on your bike?
Old Mar 23, 2015 | 08:54 PM
mikesroadking's Avatar
mikesroadking
Air Cleaner is a 7"round Harley cover with a pleated cone style
http://www.harley-davidson.com/store...18-2977302c--1
Old Mar 23, 2015 | 09:57 PM
OldEnuf2NoBtr
Are you sure that the rubber seal around the back side of the filter is seated properly all the way around to the backing plate?
Old Mar 24, 2015 | 05:37 AM
mikesroadking
Would that cause a noise only when it's warm, when it's cold there's nothing. I will check that tonight when I get home I tried getting the cover off last night, they must have used locktite it's on there pretty good. I appreciate the input
Old Mar 24, 2015 | 06:08 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Sure it will. when it's cold everything is tight and as it heats up it all expands. especially where the intake runner meats the head......
Old Mar 25, 2015 | 05:38 AM
mikesroadking
Removed air filter cover and filter and started the bike still get the same noise when warm. Sounds exactly the same it's not constant but at a low idle it sound to me like each piston going down on an intake stoke is pulling so much air it causes this whistle or squawk. Heads have huge valves and now with the flat top pistons and these cams seems to be a bad combo.
Old Mar 26, 2015 | 11:47 AM
mikesroadking
Can someone please shed some light on the whole relationship between the size of the valves in the HTCC heads in combination with the flat top big bore pistons and the SE 251 cams. Id like to know if theres anything I can do to eliminate the intake noise. I know nothing about the duration and size of the lobes on these cams and how they along with the size of the valves may cause this noise im hearing.
soft 02
Nov 28, 2013 08:34 PM
Sadthorn
Exhaust System Topics
18
Jan 22, 2011 08:15 AM
rbfrat
Aug 31, 2010 09:22 AM
outback2970
27
Mar 6, 2009 09:32 PM
BrendanGTStang
11
Oct 15, 2008 08:00 PM
