Engine Swap
Old Apr 19, 2015 | 05:56 PM
Delivery man's Avatar
Delivery man
Stage IV
Default Engine Swap
I have an 07 Heritage softail engine. I bought an 2010 road King cop bike with a bad engine. Will the 07 softail engine go in the rubber mount 2010 Road King frame.
Old Apr 19, 2015 | 08:23 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Nope.
Old Apr 19, 2015 | 08:33 PM
Delivery man
Stage IV
WHY Not, dont' I just have to change the head for that top mount
Old Apr 19, 2015 | 08:34 PM
Delivery man
Stage IV
I switch over the computer and my tuner
Old Apr 19, 2015 | 08:36 PM
QC's Avatar
QC
The engine from the Heritage is a "B" which means it has the counterbalancer system. Mounts for the Softail and a Touring frame are also different.
Old Apr 19, 2015 | 08:39 PM
Campy Roadie's Avatar
Campy Roadie
You can't interchange engines because they are two different engines; the touring bike is an A and the softail is a B motor. There's a counter balancer on the B motor that's in the way of mounting.
Old Apr 19, 2015 | 08:41 PM
OldEnuf2NoBtr
Harley makes two twin cam engines. The "A" model which is designed to run in the Dyna and Touring platforms and the "B" model which is designed to run in the Softail platform. The softail motor is internally balanced and the mounting points are in a different configuration not to mention a couple of other small differences.
Old Apr 19, 2015 | 09:16 PM
Delivery man
Stage IV
ok got it, no swapping, Will the 106 S&S pistons and jugs on the 07 B engine fit on the 2010 A engine.
Old Apr 20, 2015 | 02:28 AM
Kiwirob's Avatar
Kiwirob
Yep, - Rob
Old Apr 26, 2015 | 03:23 PM
elmerdake's Avatar
elmerdake
1st Gear
Yes, the major differances are all located in the lower block and mounting as said before. The jugs/uppers will interchange.
