Weak Throttle
Old Jun 12, 2015 | 11:25 PM
sdeck86's Avatar
sdeck86
Default Weak Throttle
Just inspected and adjusted my throttle cables. Also just moved to Phoenix, AZ where the temps are consistently above 110 degrees. I don't know if its the temperature or if there is maybe something else going on.
The best way to explain it is the engine plays catch up with the throttle. There is a slow or weak response to an open throttle and the bike doesn't seem as get-up-and-go as it used to. I've kept it serviced regularly and it just passed the 26k mile mark. Any insight is appreciated, thanks!
Old Jun 13, 2015 | 04:47 AM
chucks motorworks's Avatar
chucks motorworks
excessive heat can cause a drop in power thou if the motor is cool just after starting it should pull as it did before did the problem start after you adjusted cables or not be careful that they are not over adjusted if not make sure that the throttle is opening all the way grew up in California have ridden all my life heat is a problem been to pheniox many times you can cook a steak on the sidewalk
Old Jun 13, 2015 | 04:53 AM
Next In Line's Avatar
Next In Line
Sounds like you need to retune to compensate for the difference in altitude.
Salt Lake City, Utah = 4,327 ft above sea level
Phoenix, Arizona = 1,117 ft above sea level
Old Jun 14, 2015 | 06:14 AM
sdeck86's Avatar
sdeck86
So if an EFI is a computer controlled fuel delivery system (which my bike has), and the ECU reads various sensors that determine how much fuel to allow to the engine, then I don't understand. It's based on the sensor inputs and the fuel map, correct? I cannot confirm this info, but I've read the various sensors include RPM, engine temp, air temp, throttle position, manifold pressure, crankshaft position. Engine temp and air temp are the only ones that would apply where I am. Since it is also based on the fuel map, aside from the sensor inputs, I have questions about my TTS MasterTune2. Anyone who is familiar with this, is it possible to retune without a dyno? I think I've read/watched videos on this, but I'm pretty ignorant on this topic so please enlighten me.
Old Jun 14, 2015 | 03:40 PM
djl's Avatar
djl
Open the below link to a guide to Vtune without a dyno with the TTS Mastertune. The guide was written by "Doc", one or the best tuners in the country. Follow the guide and you will get a decent tune from the process.
https://app.box.com/shared/32spoht1c5
Old Jun 14, 2015 | 03:51 PM
sdeck86's Avatar
sdeck86
Thanks! Will do! I'll get back when I've gotten that far.
tkenney2nd@yahoo.com
Oct 26, 2016 03:32 PM
Doozie
The Dyno Room
17
Jul 15, 2016 11:25 AM
uwiik
Oct 21, 2013 01:18 PM
steveculp
EVO
22
May 16, 2012 09:20 AM
BadBagger08
Fuel Moto / Jackpot Mufflers
Sep 18, 2011 01:51 PM
