Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
91 fxrp only about 4000 miles on rebuild. Took it to a local shop to change it over to chain drive instead of belt. Apparently he didn't use any locktite anywhere the two bolts between the engine and transmission vibrated loose, all of the bolts holding the primary case to the engine backed out and the end result is the ring around the magnito that the o ring goes around broke almost all the way around.
we`ve repaired many over the years.we bore out the stock,cracked/broken ring & install a ductile iron ring,WAY stronger than stock,but the engine has to be totally dis assembled to repair
