Mechanical Question
Old Sep 22, 2015 | 08:52 PM
oakman24's Avatar
oakman24
3rd Gear
Default Mechanical Question
I have a 2005 Sportster with 16,000 miles on it. It has a really bad vibration in after you reach 65 mph when you give it gas. Could a vacuum leak cause this? What else might cause it? Your help is appreciated.
Old Sep 22, 2015 | 09:27 PM
Revmaster T's Avatar
Revmaster T
Misfire, clogged main jet if carbureted or clogged injector.
Old Sep 22, 2015 | 09:48 PM
jamesroadking's Avatar
jamesroadking
Is the vibration in the suspension or the motor? Suspension, as you give it gas and increase the speed past 65 does it start vibrating, if so, I start rebalancing the front tire, rear tire. loose axle bolts etc. If it's the motor vibrating, at what RPM does it vibrate at? Does it vibrate at the same RPM in the next lower gear at the same RPM? Does the motor rev up smoothly in neutral? Most likely dirty carb jets. Maybe a loose or broken motor mount. I personally never had a bad injector on the newer EFI bikes.
BigRedUltra
Apr 5, 2017 10:07 AM
keepriding
Sep 24, 2014 06:16 PM
see22ds
Jul 12, 2013 09:12 AM
98glider
EVO
Oct 22, 2011 10:34 PM
editbrain
Apr 15, 2010 02:00 PM
