04 fxdxi engine noise
Old Oct 6, 2015 | 01:46 PM
D-wake's Avatar
D-wake
1st Gear
Default 04 fxdxi engine noise
Bike has 39k miles
Unknown maintenance history
I got the bike and test rode it then after it sat for a 1.5 years(got it when my dad past)
Finally found time to do some work on it and went to start it up for the first in over a year and I have a ticking noise now.
I'm going to pull the exhaust/cam cover off when I get off work and check the cam tensioners but not sure if I'm headed in the right direction.
Here's a short clip. Video is horrible but I was only trying to capture the audio. Noise gets faster with rpms. The video makes it sound louder than it is.
Old Oct 6, 2015 | 02:15 PM
djl's Avatar
djl
Collapsed lifter; not pumping up and taking up the lash in the valve train. After sitting that long, it eventually might pump up but a set of Comp Cams VThunder 850.1 lifters is very reasonable, about $65 to your door. Replace them all as well as the push rod tube O-rings.
Old Oct 6, 2015 | 02:35 PM
D-wake's Avatar
D-wake
1st Gear
That's kinda what I thought. How long should I let it run to build up before I call it?
Old Oct 6, 2015 | 02:56 PM
D-wake's Avatar
D-wake
1st Gear
Actually just started it and it was running great.
Cohiba_Joe
Oct 26, 2020 08:17 PM
Z
Engine Mechanical Topics
28
Jun 17, 2018 04:33 PM
timberwolfz28
Jun 10, 2014 08:29 PM
dz1087
EVO
20
Nov 27, 2011 09:22 PM
mtnlvr
Exhaust System Topics
Apr 22, 2007 12:46 PM
