Cam and Vibration Problems
Old Oct 21, 2015 | 08:54 PM
Biker Boy 53's Avatar
Biker Boy 53
6th Gear
Default Cam and Vibration Problems
I recently had gear driven S&S 510 cams installed in an 01 FLHRCI.
I know that the tech didn't check the run out but said that he checked and the crank was true and that there wouldn't be a problem.
After the work was done engine was running ok but then the oil light started coming on, tech felt that the cam support plate was warped ( found out later that this could have happened if he used heat on it to install bearings)
He found a used support plate and put it back together but now have constant vibration which doesn't smooth out at higher speeds, feels like i'm riding a vibrator.
What happens when you pull the bearings from one plate and install in another,
could this be the problem?
Also after motor is fully warmed up I'm getting a lot of what I think is valve or rocker noise.
Any ideas?
Old Oct 22, 2015 | 05:14 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Very POOR choice of cam for an 88" touring machine.
Could be it is just stuggling to run correctly?
What did it tune off at?
Scott
Old Oct 23, 2015 | 12:24 AM
Biker Boy 53
6th Gear
Sorry that the tech that did the work gave such POOR advice said it would give me a little more acceleration off the line. Not sure what you mean by tuned off at?
Old Oct 23, 2015 | 07:43 AM
Pigbacon's Avatar
Pigbacon
He means your dyno numbers.
Old Oct 25, 2015 | 08:30 PM
Buffalolake's Avatar
Buffalolake
I run a 2001 FLHTCI with an S&S 510 gear driven cam. Normally this cam isn't recommended for an early touring bike for a couple of reasons. For one thing, it builds power in the wrong area for a heavy bike. Most touring bikes want more torque down low, where the S&S 510 is made for power up high. The cam doesn't really kick in until you get over 3,000 RPM's. It also needs a little more compression than stock to really come alive, I believe that 9.7:1 is where it wants to be. That being said, if you're the kind of rider that likes to accelerate hard and not shift until you see at least 5,000 rpm, this can be a fun cam. But you may need a lot more mods to get there.
If you are hearing rocker noise only when the engine heats up, you might not have enough preload. Have you tech re-adjust your pushrods, or learn to adjust them yourself. It's not a difficult job.
And for the vibration, you might check the front motor mount.
Timberjkd
Milwaukee Eight (M8)
37
Jan 28, 2019 07:04 AM
Lambda
Engine Mechanical Topics
31
May 17, 2016 10:39 AM
hamcentral
Jun 4, 2014 06:24 AM
FLTR2008TRIKE
15
Feb 24, 2010 02:06 PM
Neil
Sep 30, 2008 08:38 AM
