106 -117?
Old Oct 23, 2015 | 03:53 PM
brad75raiders's Avatar
brad75raiders
Default 106 -117?
I have a Dudly Perkins HD built 106 with S&S welded flywheels 4.375 stroke. Thus is a 48 mik carb 2002 electra glide .My question is can I bolt on 117 pistons and cylinders or does this need a case bore?
Old Oct 23, 2015 | 05:16 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
You'll need to split the cases to bore it.
Old Oct 23, 2015 | 05:23 PM
brad75raiders
Poop....
thank you
Old Oct 24, 2015 | 10:02 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
When we bore those to accept those 4.125" bore S&S cylinders, establishing a 117" powerplant, we also like to perform the maching operation(s) to set the client with a Timken bearing conversion as well.
Scott
Old Oct 24, 2015 | 11:11 PM
brad75raiders
Hey Scott
Supposidly crank was plugged and welded at the time of install and converted to timken
Old Oct 31, 2015 | 10:38 AM
motolocopat's Avatar
motolocopat
Displacement wise your only option without slitting cases is the 110 drop in cylinders of the MOCO. Probably not worth it for 4" unless you have a lot of miles on it and it is showing signs of wear, even then with a 106" you can still bore it.
Since you already have the crankwork you could probably have the cases split, cases bored and some 117 cylinders done fairly reasonably if you pull the motor then heads and and reinstall is just wanting to go big.
jmb79
Engine Mechanical Topics
Nov 6, 2014 07:23 AM
iaharley
May 30, 2014 12:49 PM
punkjuice
Exhaust System Topics
Aug 29, 2013 06:23 AM
chad242
Feb 7, 2011 08:33 PM
redrum
Jun 12, 2009 09:42 PM
