Compression ratio vs Octane
Old Dec 20, 2015 | 08:31 AM
Sierra977's Avatar
Sierra977
Frederic, in terms of normally aspirated engine, what you posted means that if the engine has "tuned length" input and/or output runners, the traveling reversion wave can be used to over-charge/evacuate a cylinder. More air/fuel mix can be moved in the cylinder than would otherwise be possible with normal atmospheric pressure. Similarly a forced induction engine mechanically does the same thing, moves more air into a cylinder than normal air pressure. Dynamic compression ratio increases in both cases.
Old Dec 20, 2015 | 10:42 AM
djl's Avatar
djl
The OP is over thinking the whole compression thing; this is a tractor motor not a AA fuel dragster. Set the motor up for a corrected compression somewhere between 9.3-9.6, keep CCP around 190psi, break it in right, tune and ride. This is not rocket science and "over stuffing" is not something to be concerned about.
Old Dec 20, 2015 | 12:48 PM
Frédéric CM's Avatar
Frédéric CM
I'm just trying to understand the numbers i'm told to set my engine to...
SlimJeff
Oct 2, 2012 11:50 PM
masterblaster
Apr 2, 2011 09:38 PM
hougz79
Jun 29, 2010 03:07 PM
smokindave
Mar 11, 2010 04:53 AM
Rebel78
Sep 13, 2007 06:42 PM
