Bit the bullet!!
Old Mar 4, 2016 | 12:19 PM
baloot-boy's Avatar
baloot-boy
Originally Posted by Dwill04
It does have some valve clatter at certain rpm's but going to to get the break in miles on it then will try to figure it out.
Did you also get new lifters and what preload did they set the adjustable pushrods to?
Old Mar 4, 2016 | 07:36 PM
Dwill04's Avatar
Dwill04
4th Gear
Yes, I have new lifters, although not sure about the preload. I would have to ask. Going to ride it a little while and then maybe try the Baiskey spring and cam plate to see if that helps any.
Old Mar 4, 2016 | 07:47 PM
baloot-boy's Avatar
baloot-boy
Try setting the pushrods to .140 - .150, if not set there already. That should help with the valve train noise.
Old Mar 4, 2016 | 07:58 PM
Dwill04's Avatar
Dwill04
4th Gear
I will certainly give that a try if the rattling continues. It sounds too good to rattle. Thanks for the info!
MontyCop05
Apr 17, 2013 01:20 PM
lt1tyrell
Exhaust System Topics
14
Aug 25, 2011 03:34 PM
Born2cure
Feb 27, 2011 07:43 AM
timberwolfz28
Sep 10, 2009 09:31 AM
KBES BAGGER
Apr 6, 2006 03:30 AM
