Removing auto compression release
Old Feb 15, 2016 | 02:52 PM
0425440's Avatar
0425440
Default Removing auto compression release
Is there a good way or a trick to removing the factory auto compression releases? Don't want to buy the HD tool at $41 if I don't need to. Thanks.
Old Feb 15, 2016 | 04:04 PM
prodrag1320's Avatar
prodrag1320
Take a 13/16 socket & mill a slot down the side
Old Feb 15, 2016 | 04:11 PM
GibsonSG's Avatar
GibsonSG
Order the tool from Boardtracker for only $33
Old Feb 15, 2016 | 08:25 PM
0425440's Avatar
0425440
And shipping is only $7. Brilliant idea GibsonSG!
Old Feb 15, 2016 | 08:42 PM
GibsonSG's Avatar
GibsonSG
I make it a point to add in smaller items like that with parts...>$100 nets you free shipping
Old Jun 14, 2019 | 11:18 AM
gsbuick65's Avatar
gsbuick65
I think I need to replace mine, how hard a job is this?
Old Jun 16, 2019 | 11:59 AM
k-weaver's Avatar
k-weaver
This is the way to go right here. Go to home depot, lowes, harbor freight, etc...Anywhere with chinese tools. Grab a deep socket for 10 bucks, cut a slit into it and your good to go. This is what I did, worked perfect.
Old Jun 17, 2019 | 09:50 AM
Fat11Lo's Avatar
Fat11Lo
Or the field mechanic's mill,
cut off wheel to make the slot,
die grinder to shape
flapper roll to de bur
Old Jun 17, 2019 | 09:58 AM
Uncle Larry's Avatar
Uncle Larry
"Fat" ... That's exactly the way I made that friggin' socket for tightening/loosening the turn signals on the light bar of my FLHTCU ... What a ridiculous design! :>)
Old May 30, 2020 | 09:03 AM
2017M8's Avatar
2017M8
See if there is an O2 sensor socket in that size,,,,that has a slot already milled in it,,check HFrieght
