Benefits from .030 cometic gasket
Old Feb 26, 2016 | 07:58 PM
prodrag1320's Avatar
prodrag1320
Originally Posted by Cascade
So it will be a no brainer then and I should use a .030 gasket over the standard .045.
Yup!just make sure when calculating chamber cc,you use a 030 gasket in the math
Old Feb 27, 2016 | 03:45 PM
Cascade's Avatar
Cascade
Why should that be calculated?
Old Feb 27, 2016 | 07:01 PM
ntraindavefl's Avatar
ntraindavefl
If you were doing heads, but you're not so don't sweat the chamber part. At roughly 10.5 static comp w stock head chamber (as per your pistons) plus the .030 hg you will be around the 10.7 comp mark which puts you around 202 ccp (depending on deck height/carbon build up), but basically 202 ccp which is right on the edge in a good way for the 211 cams.
Old Feb 28, 2016 | 06:32 AM
Cascade's Avatar
Cascade
Dope
So this way I'll be getting most from this build without headwork.
Should I be worried about valve clearance?
Old Feb 28, 2016 | 10:38 AM
djl's Avatar
djl
Always best to mock up and check.
Old Feb 29, 2016 | 07:25 AM
rauchman's Avatar
rauchman
Originally Posted by Hillsidecycle.com
.030" head gakets are what we use here almost exclusively, the "no gasket" comment was just to make mention of what we had done on that paticular engine.
Scott
Gotcha! Thanks!
Old Feb 29, 2016 | 12:36 PM
Cascade's Avatar
Cascade
Should I be concerned about engine longevity running the compression with the .030 gasket?
Engine has less than 3000 miles.
Old Mar 1, 2016 | 12:43 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
No.
You'll be fine.
Scott
Old Apr 19, 2016 | 10:20 AM
Cascade's Avatar
Cascade
When installing the cometic .030, is it necessary to remove rivets?
Old Apr 19, 2016 | 10:30 AM
djl's Avatar
djl
No! Install as it comes out of the package. Follow instructions regarding the oil return dowel O-rings.
