Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
No need to purchase heads to get smaller chambers; deck your OEM heads to achieve the desired chamber volume. If compression is an issue, have manual compression releases installed in your OEM heads. A decent 107 kit can be put together for much less than $1700 in parts......
Bore your stock cylinders, port your stock heads, in my neck of woods is close to $1700 and no cams,pistons, pushrods, gaskets etc. Depends where you live how much it will be , unless you wanna drive to Fuel Motto you cant beat there prices even with install.
You are getting ripped off. Bore cylinders and fit new pistons; just had a set done for a 98" build by Lozano Brothers for $550 out the door with CP pistons and an extra set of heavier pins. Head work by Lozano will run about $800 including new head gasket. Me thinks you need to look for another shop if you are paying $1700 for a bored set of cylinders sans pistons and head porting.:iconk_doh: Or start sending your stuff out to Scott or Kirby..................
Heads with shipping $1000 ( Jonny Sachs) bore cylinders with Wiseco pistons $600-700 at least here from any local guy. Your Lozano Bros is $550 plus heads $800 thats not that far off from what it costs up here. You could probably swing a cash deal in the off season for less . Ive run JS heads forever no complaints here Ill pay the shipping or extra . Not tring to be argumentative just stating the costs as I know them in my area. Appreciate your posts you know your sh+t on all things engine related.
Reason: Grammar
Sachs is one of the best; highly respected and low profile like Mike Lozano. I wasn't being argumentative either, just saw $1700, no pistons and that is out of line no matter where you are.
Back in early 2000 I had a set of heads from Bill Bishop ( Hammer Heads) not to shabby either but JS is the man and has been for myself and many others in my neck of the woods.
