Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I'm buying a 48 el case set it's really hard to find el parts so if I bought fl top end would it work? Pistons hugs heads.. Also would a fl flywheel work in the case also? Basically could I have a fl in a el case I didnt know if the cases were different from 61ci to 74ci
This will help you out http://www.terra-glide.net/panhead.html ,but I remember putting 74 jugs and pistons in a 61 makes 68inches which works very well.The 61,s would outrun the 74,s up till 3rd gear and a 68 would get them to a 100.Thats with a 68 shovel cam.
The 61"s had a 3 1/2" arm, and the big 74"s had a 3 13/32" stroke.
The 74" cylinder on the smaller stroke would've resulted in the piston being down in the hole by about 7/32".
Larger cubes, but with the ability to run on kerosene, unless the cylinder was mounted in a fixture and .218" removed from the cylinder, bringing it back to about 7.0 cr.
Scott
