Weight difference between 96" and 117"
Old Apr 7, 2016 | 07:36 AM
NascarGuy's Avatar
NascarGuy
Default Weight difference between 96" and 117"
Finally finished up my 117 build/install and am curious if anyone knows the weight difference between a stock 96ci and a 117ci. I have put 70,000 miles on my old setup with a fair amount of mountain twisty riding and am noticing a different feel in the corners especially when doing downhill twisties. Things definitely feel different
Any info would be appreciated
Old Apr 7, 2016 | 09:32 AM
djl's Avatar
djl
I don't know but thinking about it, the only component that adds any weight is the rotating/reciprocating mass of the crank and pistons; all other components are the same. I can't see how there would be much difference in weight between the two but truly don't know.
Old Apr 7, 2016 | 09:39 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
About the same weight.
Scott
Old Apr 7, 2016 | 01:22 PM
NascarGuy's Avatar
NascarGuy
Scott
Was thinking about the increase in piston size and crank weight plus weight of 110 with larger valves vs stock. All and all the bike just feels heavier.
Maybe i'm loosing it!!
Old Apr 7, 2016 | 03:02 PM
msocko3's Avatar
msocko3
It's going to be a touch heavier, but nothing you're going to notice. When I built my 120, I built it on the bench, then removed the engine I had in the bike and put the completed 120 in. The previous engine was a 95", I didn't notice much difference picking the 2 engines up and carrying them across the garage.
cdonis's Avatar
cdonis
No offense, it's probably your heightened senses, and you being more cautious with the new ponies.
Old Apr 7, 2016 | 03:44 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
It shouldn't be more than about four to five pounds if that much.
Old Apr 7, 2016 | 04:10 PM
ntraindavefl's Avatar
ntraindavefl
Maybe check the area between your chest and belt area. I've heard it all now.
Old Apr 7, 2016 | 05:50 PM
Tedwilliams09's Avatar
Tedwilliams09
Dave.. Dang you that is the second time in three weeks you have cost me a cup of coffee
Old Apr 7, 2016 | 08:54 PM
ntraindavefl
Hey hope that coffee's not too pricey.
BTW an 800lb bagger w stage 1 hp and a rider that gains 20lbs on the gut will "feel" roughly a 3 hp loss...................
