Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Just finished up a FM107 kit with level B heads on a new ultra limited.
went out for about 2 easy miles and have a pretty good amount of oil coming from what appears to be from the air cleaner.
Anyone have any thoughts? This is my second 107 kit and did not have this problem on the other bike.
Thank you
