Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Posted under another heading but this one captures the issue better.
Saw a video on youtube claiming there were some inherent defects in the design of modern HD motors. One thing the narrator said was that the pressed flywheels were inherently badly designed and were likely to cause vibration after many miles and also cause catastrophic engine failure after wearing the bearings.
Any truth too this? - or is it just a beat up? Thoughts welcome - especially from those who have put on a few miles... Are we really sitting on ticking time bombs awaiting catastrophic engine failure as the video suggests?
Youtube video title is: HARLEY TWIN CAM ENGINE DESIGN PROBLEMS
Relax. These are all "features"...lol.
Per an HD mechanic I trust, never use 6th gear under 65, too much stress on the crank. Keep an eye on your cam and primary shoes, and you are good to go.
Ride safe.
The guy in the video is right.... at 0.3" run out on the crank you're gonna have problems.
Wonder if he has a video series available...
__________________________________________________ ____ For ROCKOUT information & purchasing please click the LINKSbelow...
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
Runout is the 'wobble' that a crankshaft has when it is not perfectly true (straight). There is a tolerance that HD says is acceptable, check your service manual for your particular bike.
