Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Need some advise, I recently installed Woods 222 cams in my 2015 CVO Street Glide.
What a difference it made to my bike I love these cams for my style of riding, I was thinking about getting some head work done and was wondering what would be recommended, what would be the maximum compression allowed for the woods 222 cams. I was also thinking about upgrading to a 58mm throttle body
9.8-10.0 would be the threshold for the 222.
The 58mm has a port diameter that matches your head port opening vs your current t/body(50mm I assume).
Scott
10.2 max... That would put you at 200 ccp..... 85 cc heads and a .030 head gasket with .005" piston in the hole will get you there... Without the right pipe a 58 mm tb might be a little over kill... and still probably will be with that Woods 222....
I'm not looking to do anything to the bottom end such as pistons
I already have the Woods 222 cams installed
I don't know what I can do to these heads with these cams ? I've was thinking of changing out valve springs, guides etc maybe even a valve job as well while I have the heads off
