Unusual idling
Old May 15, 2016 | 03:20 PM
djorgensen3's Avatar
djorgensen3
Look in your owners manual for the procedure to disable it if you need to.
Old May 15, 2016 | 07:47 PM
baloot-boy's Avatar
baloot-boy
You can raise the temperature setting to enable EITMS using your Power Vision.
Old May 16, 2016 | 08:34 PM
MURPHCC1's Avatar
MURPHCC1
http://wardspartswerks.com/cooling-fans.html
BEST EVAH!!
Old May 17, 2016 | 06:46 AM
todd-67's Avatar
todd-67
Originally Posted by djorgensen3
EITMS...? Engine Idle Temperature Management System. Rear cylinder drops off over a certain temp.
^^ this. My 10 just started doing this after adding cams. Probably can be reduced with a good tune.
Old Jul 5, 2016 | 09:00 AM
tydaniels's Avatar
tydaniels
Default sound
that's exactly what my bike does after idling for about 25 seconds; I was about to take it to the shop and have someone look at it... Thanks for the info guys...
Old Jul 5, 2016 | 09:39 AM
FlaHeatWave's Avatar
FlaHeatWave
EIMTS can be turned on / off, key on, run switch on, engine not running, twist throttle forward, cruise lamp will change to red or green...
or it's covered in the owner's manual, no need for a Tune...
Old Jul 5, 2016 | 02:26 PM
cdonis's Avatar
cdonis
Originally Posted by EricRay
Thats a relief, kind of sounds weird. May think about installing some fans.
Thought about buying some wards fans. They won't fit but maybe a guy could modify them to fit.
Old Jul 5, 2016 | 04:36 PM
edtekk's Avatar
edtekk
I have a 117" on my Slim and installed the Wards fans. Worth it in my opinion.
Old Jul 5, 2016 | 08:03 PM
cdonis's Avatar
cdonis
For sure, talked to Jason at wards fans, apparently the breakout coil poses a problem.
Old Jul 10, 2016 | 07:59 AM
nick@nite's Avatar
nick@nite
Here's what she sounds like. And yes, it only does it when it is hot.
Attachment 472220
Man i had a flashback on was on the side of my old foxhole bud firing his M-60 lol all kidding aside when you twist the wick your bike sounds good!
Calvin1989
Oct 13, 2016 11:42 AM
oldlefty
May 18, 2015 11:17 PM
HogWildRazorbacks
Feb 26, 2009 08:06 AM
frankiebracamonte
Sep 12, 2008 06:11 PM
pwr96
Exhaust System Topics
Dec 17, 2007 06:50 PM
