Pushrod Adjustment
Old May 20, 2016 | 08:36 AM
djl's Avatar
djl
Originally Posted by mike_oh
The kit on the S&S site says Evolution but do they work in TC?? Specifically the motor listed in my sig and would it be advisable to use them? I would say my top end is not particularly noisy but quiet would be nice. I have heavy beehive springs and the .625 lift cam. The flywheels are lightened and it revs quickly with the limiter set at 6200. Any thoughts are appreciated!!
Travel limiters will not quiet your valve train but replacing the Fueling lifters with a set of S&S premiums with a bit of extra preload might help. You mentioned "heavy" valve springs? Don't know how heavy but a lighter spring might help as well. Sometimes spring pressures are OTT and slam the valve back into the seat which contributes to top end noise................
Old May 20, 2016 | 03:42 PM
mike_oh's Avatar
mike_oh
Smile
I had the heads set up and flowed by Dan Vance so I really don't know how "heavy" the springs are and he knew everything going into this build. When I first got the build done I was surprised how quiet it was. I run Redline 20-60 in it and it runs fairly cool. Oil temps in the 200 range sometimes 220. In traffic the heads do get hot but some Wards fans are going to help that out. In retrospect I would have gone with S&S lifters and cam-plate and pump although I have had zero issues with the Feuling parts. Oil pressure is good and blow-by is minimal. I do have some hot start issues although not severe and I have comp releases and that is the reason I was asking about the limiters. :-)
Old May 20, 2016 | 05:38 PM
Wv7o's Avatar
Wv7o
If I follow, I think you understand the general purpose for travel limiters with the caveat that bleed down rate is going to depend on the internal tolerances of a lifter. IAW, an S&S Premium will not bleed down as fast as the OEM lifter. If clearances valve to piston clearances are measured and adequate, running lifters at .145" preload is not doing to damage anything.
I agree that bleed down rates between lifters would be something to consider and I understand the caveat.
I appreciate your responses and input.
thank you
Old May 21, 2016 | 02:53 PM
mike_oh's Avatar
mike_oh
So I decided to get a set of S&S Premium lifters and ordered the limiters as well. Any advice on adjusting the push rods is greatly appreciated! I have the SE tapered adjustable rods.
Old May 21, 2016 | 04:40 PM
djl's Avatar
djl
Different ways but my way follows:
1. set the piston on the cylinder you are working with at or very near TDC on the compression stroke. You will know by placing your finger over the spark plug hole; the compression will push your finger off as it comes up.
2. Adjust each pushrod and set preload at about .135" which is going to be 4 turns plus 2-3 flats.
3. Let the lifters bleed down until you can rotate each one with your thumb and forefinger before rotating the crank.
4. After bleed down, rinse and repeat on the other cylinder.
No need for gorilla strength when tightening the jamb nuts but they do need to be tight. Some use a tiny bit of red thread lock just between the jam not and the pushrod base on the final tightening............
Old May 21, 2016 | 08:15 PM
Wv7o's Avatar
Wv7o
Current Screamin Eagle tapered pushrods are 24 tpi so he should adjust 3 turns plus 1 flat to be at .132, if an older set of pushrods they could of been 32 tpi then 4 turns plus 2-3 flats.
Old May 21, 2016 | 08:48 PM
djl's Avatar
djl
Good catch and correct. If the OP is installing the SE pushrods (Quick Install Tapered, PN 18404-08 IIRC), they are 24TPI; I go 3.5 turns (3 and 3 flats) on those. Running a set in my all bore 107" '02 FLHT...... First ones out had issues with poor quality adjustor nuts that were brittle and would crack or break but all sorted out now.
Another tip on adjusting pushrods for a newbie. Do it with the cam cover off and, with a light, you visually confirm that the lifter is on the base circle.
Old May 31, 2016 | 05:57 PM
mike_oh's Avatar
mike_oh
So I have the S&S premiums and the HLT2 travel limiters. The link is from S&S web site and it seems to use the the method as Wv7o describes in his first post. S&S is saying after adjusting for zero lash to shorten push rod 1 turn (for 32tpi) and tighten. I know it will be different for 24tpi which is what I have but 1 turn???? Is that enough?? One turn on 24tpi is .0414 if my math is right.
http://www.sscycle.com/tech-info/pus...ustment-guide/
Old May 31, 2016 | 06:34 PM
markwolula's Avatar
markwolula
When its a new installation, I cant understand why this advice/tip, it not mentioned more !!!!
Also if you are cutting pushrods, (ie, not removing rocker), same advice/tip applies !!!! For first time installation, (newbies), it take the guess work out of the equation, and they can install more confidently !!!!
Old May 31, 2016 | 07:09 PM
djl's Avatar
djl
You are where almost everyone I know that is new to travel limiter is; don't know how to adjust. You don't need travel limiters; a set of standard lifters like S&S, Comp Cams, Woods, Gaterman, etc. are very straight forward; no tricky adjustment procedure. Good luck with the travel limited lifters. You do know that you can remove the HLT2 limiter kit??
