Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
thank you djl. you answered my question in the tensioner post right below this one. .003. like i said im a machinist and .003 is a **** ton. when i check mine, if its over .003, i would have a hard time even putting chains back in. to me that is to far for any runout. maybe not but i deal with .0005 all night so .003 is a lot
So, you think .003" is a lot? That was the HD spec for warranty purposes up to the '07 model year when that spec changed to .012" which was coincidental with moving the supply source for cranks offshore. .003" is still the "recommended" max total runout for gear drive cams but I do know a couple of guys that have run gears at .004". Andrews makes over and under size gears which are sometimes required for proper fitment. I am running gears in one bike at .0025" with no issues. Chains can tolerate much more runout.
yes I understand that chain can withstand more. like I said. im a machinist, I hold +/- .0005 which is .003 times 6. how long will a motor last with .003 or under runout with 30,000 miles?
I think you mean that .003 is .0005 time six??
Long enough to wear out the top end if the motor is properly maintained. Even a trued crank will show .0015" runout. You have to remember that the HD vtwin is not much more than a tractor motor; same basic design for 75 years and a motor that rarely sees 5000 rpms and in that world, .003" is pretty tight......
Long enough to wear out the top end if the motor is properly maintained. Even a trued crank will show .00015" runout. You have to remember that the HD vtwin is not much more than a tractor motor; same basic design for 75 years and a motor that rarely sees 5000 rpms and in that world, .003" is pretty tight......
I agree.
Having served thru a NYS Toolmaker apprenticeship in the mid '70's, and having manufactured the driveshaft ship-sets(4 pcs.) for the AH-64 Apaches for Hughes, and holding .0005", T.I.R. and .0005" on the bores...........on the 10' fters!!!
Knowing when to be fussy and what your working with, is a balance that comes over time.
Scott
.0035 is where we like not using gear drives,we have installed them at .005 once (against our recommendation & no warranty),bike is still fine after 3 years.
We've seen Evo's (read gear-driven cam chest) with OEM .005"-.007" TIR(and more) on the pinion before with 50-60,000 miles on them.
Cam cover bushing was out of spec.
Certainly not what anyone wants, and yes, a true crank is the way indeed.
Scott
