Cam plate differences
Hope this helps.
JMHO but I think the early OEM cam plate, aside from the fact that it is not as stiff as a billet plate, is a more robust piece of hardware having a rear roller bearing (since 2000) and a front ball bearing. Again JMHO but I also think the both the early OEM plate and both billet "upgrade" cam plates have more than adequate outboard support for the cams, chain or gear driven also knowing that the chain drive system puts heavier loads on the outer rear cam bearing than gears. And, yes, I totally agree that gear drive cams work on TC motors and forever eliminate any tensioner concerns.
Polishing the early chain on the outside worked on early tensioners that were replaced by new; no reason to polish the back side. Anyone that polished a chain and did not know any better than to remove the grit just didn't know what to do.
The points I was tryin to make in my previous post was that there is no issue with outboard support for gear drive cams in the early OEM cam plates; certainly better support than provided by the later OEM cam plates but, of course, JMHO. Chain drive cams put more load on the rear outboard support than gear drive cams do. Not sure how that relates to your "more efficiency as far as drive load" comment but I interpreted it as a comparison between applied load on rear outboard bearing between gear and chain drive systems.
Not sure what you mean by "true CYCO data". Scott has installed many CYCO tensioners and I don't believe he has any "do overs" yet; might check with him. Certainly, the CYCO approach with the early cam plate and an pump upgrade to a Daytona pump or even a Zippers shim or Baisley spring is an upgrade and will last a long time but does require a periodic check. The way most of us ride and as I previously stated, that upgrade will last way longer than most will own the motorcycle.
I agree with QC on the 37, too soft on the bottom for an 88". Better choice is S&S 509 or the Andrews 26; JMHO, but the 509 is a better cam choice for a cam only upgrade in a TC88......
Do the same sprockets work? Or will I need new sprockets also heard something about a weak bolt or something I think the one that holds the gear on but I'm not sure.
What I referring to as out board support in my original post was the end of both cams use to have bearings journals on the end that was supported by the cam cover. That was what was eliminated when they went to the TC chain drive.
And yes my year has cam position sensor I might be wrong about the years bearings changes on cam plate I'm not sure on that. I'm not trying to go roller chain I'm just not sure they make cams that are both smooth to fit the round style bearing I will call Andrews again on Monday and see what they say I guess.
I believe what you are referring to may be the difference between the keyed sprocket on the '99 models and the splined sprocket in the later models; not sure what year keyed change to splines but it could have been 2000 which was the same year the rear outer bearing was changed from ball to roller.
So, if you have cams that are have a keyway in the nose, you will need a keyed rear pulley and if you have cams with a splined nose, you will need a splined sprocket; either will work, splines are better. I have attached a link to the Andrews instructions for this install; should help clarify the install for you.........
http://www.andrewsproducts.com/files...-1999-2006.pdf
If I understand correctly, you are just changing cams and upgrading the inner and outer cam bearings. If that is the case, all you need do is follow the instructions, refer to your service manual and make sure that the rear cam sprocket is aligned with the crank/pinion sprocket. It may line up with the OEM spacer but might not with new cams.
Not exactly sure what tcarson is going to do but if he goes gear, think the outer must remain chain with the cam sensor. In my opinion, his tensioners at 17 years need to be changed regardless of mile do to heat making delrin hard.
