Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
My stock 1992/FLSTC misses on acceleration from cruise. Won't go over 70 and also misses on hard acceleration.
Any ideas? I replaced the voltage regulator to to a discharging problem and that seems to be fixed.
Bad plug wire or coil most likely, but it could be a carb problem...torn diaphragm, blocked jet, or badly mis-jetted.
I have the same symptoms and a fuel pressure test showed a drop in fuel pressure on acceleration. Even though I have a fuel injected model and you have a carb'ed model, the results are the same.
It appears to be fixed. I replaced the voltage regulator and had to trim the plug in housing to make a secure connection. That helped but....then pulled the air cleaner element. Not horrible but not good. Then replaced the spark plugs and took it out. Varooom! Nary a miss or bog. Felt sooooo good!! Too much drama I know but dang it it felt good!
