Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Damn! Didn't do the o2 sensor. Is it worth removing the front exhaust (thats the only one I removed for the cam job) to get at the O2 sensor and get some anti seize on it? The floor board isn't on yet.
If you decide to put the anti-seize on the O2 sensor be careful not to get any of it on the actual sensor itself. Threads only.
