Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I have already changed the transmission and motor oil and I run Mobil 1 V-twin 20W-50, cleaned up the throttle body and tested to see if there were any leaks by the intake. Not a head gasket, no leaks.
I have been told on roadglide.org that it may be a rocker arm
